AlexMcK
- Jun 11, 2015
- 4
- 0
- 0
- Location
- Melbourne
- VR Commodore
Hi all, I got the Commodore V6 VR from my auntie for free as it needed a bit of work. I took it to the mechanic for the leaking power steering and the rack ends were replaced. However, didn't fix the problem. Have been neglecting the problems for a while, but recently decided to see what I can do to help/repair them. In advance I would like to thank all input
Problems:
- Power steering leaks (if above ~1/2 full reservoir)
- Coolant leaks (working on)
- Fan speed 3 and 4 not working FIXED
- Gears take a few seconds to change and clunk (going into D and R)
- Roof liner falling off
- Radiator fan may not be working
- Tyre leaking (needs refill ~1 month)
- Odometer stopped
What I have done:
Coolant leaking
- Flushed coolant
- Refilled coolant w/ Nulon Stop Leaks
- Replaced radiator cap
(19-06-2015)
- Replaced thermostat and gasket
Radiator Fan
- Fan didn't turn on while idling for ~20mins
- Fan turns on with A/C
(19-06-2015)
- Fan comes on with temp. sensor disconnected
Fan Speed
- Replaced fan resistor with solid state resistor (off ebay $20)
I understand gear box clunking and slipping is probably not something I can fix too easy?
Roof liner is annoying either I tear it off or was thinking of pulling it off to one side then getting liquid nails and sticking it back on. Though there was orange stuff that slowly cover the car in orange dust under my sisters roof liner. I defiantly don't want that.
Was wondering anything that has worked for others that might work on the tyre or I just suck it up and wait until it is a real problem and replace them.
I replaced the radiator cap with a new one, though the one originally on there was a 100kPa, I manage to get my hands onto a manual for Commodore/Lexcen 1993-1997. The cap pressure is noted as being 120kPa-150kPa for the V6. Is there any need to replace the cap again? Is there any reason that it is low? Possibly because older hoses, radiator and possible leaks?
While flushing coolant and adding "stop leaks", I had the car idling for about 20mins. The fan didn't come on once, as I would have noticed as my head was under it looking for leaks developing. Though it did come on with the A/C. Either this could just be because the temp didn't raise enough, or the temp sensor isn't working. I believe to test temp sensor (under alternator on the right) unplug the wires to it. The fan should spin up in 12secs and max out in another 6secs. Do I need to replace the alternator and drive belt to do the test? Also does the car need to be running?
According to SuperCheap this is the themostat you need : Tridon Thermostat - TT203-195 - Supercheap Auto Australia
This gasket goes with this thermostat : http://www.supercheapauto.com.au/online-store/products/Tridon-Thermostat-Gasket-TTG46.aspx?pid=11238#Recommendations
One last thing, after refilling coolant my partner was driving behind me for a little. She saw liquid coming out of the exhaust and a bad smell coming from my car. I did spill a bit of coolant over the radiator, it has been reasonably cold and it was the first time driving it for a couple of days. Though could there be coolant getting into the engine and this is why the coolant is leaking? If so how much work would it be and tools I would need to fix/test this problem?
Sorry for the wall of text trying to get all info out there
Problems:
- Odometer stopped
What I have done:
Coolant leaking
- Flushed coolant
(19-06-2015)
Radiator Fan
(19-06-2015)
Fan Speed
