ant27485
Hi ,so I got a vyss. Got exhaust, extractors and a bigger cam fitted by castle hill performance , all work done has been professionally done . Well anyway the car decided to crank but not start , after a few attempts it fired and all is well , anyway as time went on it happened more often so took it to the mechanic , firstly they said it was the fuel pump replaced that still did it , next I was told it was the cas replaced that still happening , next I was told it was the oil pressure sensor changed that still problem , next I changed keys still the problem , anybody have any clue what could be causing this ? I do know when it cranks and doesn’t start I do get fuel pressure but no ignition pulse or spark. The car is now at a third mechanic and they aren’t sure , no error codes had been logged
