VTsuper6 said:
I tend to agree. But would you call it Quality or a Tolerence issue? Obviously GMH developed a testing criterea to determine which engines are worthy of a warranty repair or not. I'd say the ones way out of tolerance are repaired and the marginal ones are knocked back. Personally, I think if Piston Slap is detected by the Holden Dealer and if the Customer is unhappy with it, then Holden should Authorise a warranty repair.
Do you mean owner tolerance and Holden quality?
Tolerance and quality go hand in hand. The issue hear is that Holden have devised a level by which they can minimise the extent of work and therefore cost to them. There has to be a reasonable level of oil consumption so that valve stems and piston skirts get lubricated. The level set is probably a tad on the high side from feed back through web pages. I totaly agree with your statement about piston slap. On a modern engine this should not exist and has not for a number of years on many engines of various brands but recently has come to the fore again where manufacturers have had a problem where possibly a supplier has engineered the piston for a specific application and f**k*d up. This again may be a quality issue with the supplier as mentioned before where they are not adhering to there own standards or the customers standards ie the vehicle manufacturer.
I would also like to point out that there are two forms of piston slap with a new engine so I'm not talking about an engine that has done high K's and is worn.
Cause - A piston that slaps has a large skirt clearance or is quite short and rocks around the gudgeon pin.
1] The piston can simply knock once every power stroke or in worse cases every stroke which will cause a loud metalic sound and go away once the engine is warmed but does not have excessive oil consumption.
2] The piston can rock in such a way as to cause the rings to flutter in the grooves. This pumps oil past the rings or they are merely are not touching the bore at all times causing oil to go past the rings to the combustion area. Such a situation will cause excess oil consumption which may or may not cause an audible knock.
The root cause is the same as in Cause above.
