sweefu
- Dec 1, 2008
- 2,742
- 6
- 38
- Location
- Canberra
- VY Berlina V6 / R31 Skyline
Sweefu, that looks good, can it be as simple as drilling a hole and putting them in, or would they need to be angled and some fibreglassing involved?
There isn't enough room behind the A pillar trim to fit the tweeter, so it would have to come out a bit, probably a 9mm mdf ring would be enough. If you wanted you could cut the hole, test fit the tweeter and glue the ring in place, then use some filler / glue to fill the gap, sand it and trim it. Even with the tweeters firing straight across the dash your sound stage should be improved from tweeters in stock locations.
