Noise at start - cam shaft actuator
JoeRogan
Gold Coast, Australia
2015 Evoke Sedan
When I start my car it makes this noise.
I recorded it and youtubed it to send to holden before I book it in. ----> https://www.youtube.com/watch?v=hjHX5tvdeyg
They said it's the cam shaft actuator. I'm dropping it off next week for a warranty repair.
I just want to know how 'bad' it is and any background info. i.e. do the timing chains need to be replaced at the same time? or do they put the same ones back on when it's repaired? Is it a big job for them to fix it?
Any info would be good.
I've got 2012 VE Series II - 78,000 kms
thanks :D
Sean880
VIC / NSW
2012 VE SV6 ser 2 and 911 Porsche Carrera S 997
If there is a fault with a camshaft position actuator the diagnostic check will throw up codes and they will investigate the cause from there.
There are a number of possible causes for malfunction so they will have to run tests to identify the specific cause in your case. They may well just find a problem with an actuator solenoid. You have to leave it to them to run the test procedures and find the cause so there is no point in asking people to speculate on what repairs or replacements will need to be addressed.
At what kms was the oil last changed in the engine and what type of oil and viscosity of oil was put in the engine last time.
JoeRogan
2015 Evoke Sedan
It's got 77,xxx kms. It was last serviced at 70,000 kms using Penrite 5W30 oil.
It's been making a version of the noise for about 15,000 kms. Gradually worsening over time.
Jackndad
51
Vy Crewman SS
thanks :D
Hey I know this is old post now but my car is making the same noise, was it the cam actuator
Fu Manchu
WA.
Could it be the starter gear not engaging the fly wheel correctly?
Martbar
67
New Zealand S.I. Otago.
2016 VF Series 2 SSV Redline.
OP hasn't logged on for about 18 months, don't hold your breath, but you might get lucky.
Be mindful that even though you think its the same noise, it could be something else. If you don't have any contact with the OP, it would be worth getting it checked out by a competent mech. Noises seldom get any better. Good luck.
Fu Manchu
WA.
Could be the timing chain on the timing case as well.
krusing
Melbourne, Bayside
Is it usually a cold start?,
and/or when it’s been sitting a while ?
then disappears after approx 5 seconds,
What year ?,
How many K’s ?
Can you provide a small video of the noise that may assist with some
answers comments from other members.
redsherran69
perth
'10 ve sidi sedan / '09 ve international wagon
Pretty sure its the o ring in the oil pickup , mine did the same on cold starts when I first got it , but regular services every 5k kms hasn't done it since
