Greenow
- Jul 21, 2018
- 2
- 0
- 1
- Age
- 62
- Location
- Adelaide
- VE Calais V8
I recently got my VE Calais V serviced after driving it for 6months with the check engine light on....I knew what the fault was and to cut a long story short left it because the AFM was disabled and the horrible noise coming from inside went away........ The ECM had disabled the AFM after constant oil pressure warnings...The mechanic after some help and education found the filter screen for the Vlom below the oil pressure sender and cleaned it...The AFM is working again and the horrible noise has returned.... I assume it is a failed lifter but cant work out why it only makes the squeaky scratchy noise when the AFM is enabled.....HELP!?...I am thinking full rebuild??
G
G
