I run E10 (94ron) no prob. Was a firm disbeliever in it but after some reading, its fine and rather use this. In fact car loves it.
Also check out which below is very surprising
E10 Very similar to 95ron in performance but does use up a fraction more.
For all round performance to economy, 95ron is like the sweet spot.
98ron for tuned but tuners can also do a 95ron tune.
91ron, which can contain up to 10% ethanol anyway is not my fav at all.
Had issues with misfire under load using 91ron and went with 95ron and E10 and now no issues at all so i avoid 91 when I can.
From memory the comparison between fuel usage between fuels is below
E10 to 91ron - 2-3%
91ron to 95ron - 2%
95ron to 98ron - 2%
The only issue is to simply regular maintenance.
Change fuel filter to make sure its clean.
Run a fuel system cleaner every now and then and make sure you use really good oil
