I have a VZ Berlina with climate control. When the engine is under load eg going up a hill, the airflow will divert from the dash vents to the windscreen demist vents until there is no load on the engine. The effect is loud wind flow noise form the demist vents, no air from dash vents at all until the airflow is again switched back from demist vents.
This happens no matter what the aircon control settings are at, but seems particularly bad when the climate control is set at about the same as the outside temperature - wind up the climate control temp to a few degrees above ambient and the problem goes away.
This has only recentrly started happening Anyone any ideas?
