Curious what the oil look like 12 months and 800 kms old?I do mine every year because it doesn’t do much, due in September and under 800km travelled since last September.
Same here, my ve has only done 2000km since oil change a year ago I’m still changing it anywayI do mine every year because it doesn’t do much, due in September and under 800km travelled since last September.
And this is the elephant in the room, looking at oil with your calibrated eyeballs, or sniffing away for fuel contamination will not give you a breakdown on what is actually happening inside your engine wear wise, or the actually condition of your oil and its additivesCurious what the oil look like 12 months and 800 kms old?
Ever done an oil analysis?
That’s all true but if one dumps oil after 2000kms and it still is a nice clear clean light brown, does one really need to spend $30 -$50 on oil analysis?And this is the elephant in the room, looking at oil with your calibrated eyeballs, or sniffing away for fuel contamination will not give you a breakdown on what is actually happening inside your engine wear wise, or the actually condition of your oil and its additives
I'm of the opinion that if you can see or smell anything out of the ordinary, as was mentioned earlier in this thread (and apologies to whoever said it 'cos I've forgotten who that was ), that analysis is probably pointless because something probably IS wrong so I don't know what value an analysis has? Like if you can smell fuel, if it looks watered-down, if it's got sediments (or worse - shiny bits!), if it looks more dirty than you'd expect ...And this is the elephant in the room, looking at oil with your calibrated eyeballs, or sniffing away for fuel contamination will not give you a breakdown on what is actually happening inside your engine wear wise, or the actually condition of your oil and its additives
The analysis will tell you what is breaking down, is it bearings, is it brights, is it because of the oil has lost its shear strengthI'm of the opinion that if you can see or smell anything out of the ordinary, as was mentioned earlier in this thread (and apologies to whoever said it 'cos I've forgotten who that was ), that analysis is probably pointless because something probably IS wrong so I don't know what value an analysis has? Like if you can smell fuel, if it looks watered-down, if it's got sediments (or worse - shiny bits!), if it looks more dirty than you'd expect ...
I just changed the oil in my SSVR Ute after 9 months and 155km's. Oil looked practically brand new but I'm thinking is an oil change really necessary at 9 month intervals when the car isn't driven much? An oil analysis in these circumstances would likely confirm if the oil change intervals could be extended. I'll start my Ute up 2 or 3 times a week and move it between sheds and take it for a spin around the block sometimes, with a few cold start and condensation factors at play that I'm not sure how relevant that is to oil deterioration.if one dumps oil after 2000kms and it still is a nice clear clean light brown, does one really need to spend $30 -$50 on oil analysis?
