Nuddy989
Well nuddy thanks for your input but on the otr website i went to thats what they claimed (14kw) which is around 7hp, Dont know where your getting 20-30 RWKW from as thats a big jump even with a good tuner....Just for the record i ended up with 251.1 rwkw from 1 5/8 headers, and 2.5 exhaust, and just a K&N filter in standard air box...Not a bad result id say...If i must put an OTR on at a later time i will do and get it tweeked up if it needs it, untill then im frying tyres....
that's without a tune
like somone else mentioned if you had the OTR you would of gotten 265-275 out of it.. the car would also be a bit more responsive and you can actually here the car breathing with an OTR.
you will need an OTR if you do any more mods and either the VCM or the duspeed ones are good. there are other ones around but they're the two that most people seem to use
