probably the resistance of the globe(s) is what you seeing as a circuit how many ohms did you measure?There is continuity when I flash the high beam, no battery connection
You've lost me I thought we were working on the ignition circuit ? Is it a direct short your seeing with the tester that shouldn't be too hard to find it would be blowing the fuse?All globes and instrument cluster were removed
I have checked my other VP and its the same.You've lost me I thought we were working on the ignition circuit ? Is it a direct short your seeing with the tester that shouldn't be too hard to find it would be blowing the fuse?
the coil wont have much internal resistance .
What the fuel pressure regulator like? If fuel has been flooding the plugs, they maybe cactus?When I crank it it wont fire but can smell fuel
