J
JohnW
Guest
Doing the intake manifold gaskets is not expensive or complicated and anyone with a moderate skill level should be able to do them in a couple of hours. You only need a 3/8 spanner and some silicone sealant for the ends of the valley seals where they meet the intake gaskets. Undo all the bolts, lift the manifold up, get a mate to hold it up, pull out the old gaskets and place the new ones, silicon the ends of the valley seals, put the manifold back down and replace the bolts in sequence and torque to spec. It is not inconceivable that a system can leak under vacuum but not leak under pressure. as to why the temperature shoots up and down if there is air in the system I don't know, I just know it does and keeping the coolant topped right up stops it from happening from my personal experience.
Your advising someone who seemed unsure about removing the serpentine belt (were it necessary), that the next thing to tackle is pulling half the top end off their engine.
And I would certainly not recommend to anyone to do it by your backyard method. Remove everything and do it properly (to most people that means buying a small scale accurate torque wrench, cost about $150). To pay a professional to do the job properly, about $700 would be a reasonable price
