by 'clear over base' i mean a thin colour, like a metallic with clear over the top of it, the colour being the 'base'. solid colour is just a flat colour with nothing else in it, so a white or red or blue or whatever.
good spray painters in the right conditions can get paint perfectly flat straight off the gun, but you and i are not good spray painters and we prolly dont have perfect conditions
![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
so we need to prepare for peel. blocking it back is basically getting a block, i've been using a thick rubber thing from the paint shop. was like...10 bucks or something, looks like a square thick soled thong.
so what you do is spray over some guide coat. cheap 'export matte black' is about 3 bucks a can. you dont need to spray it on thick, just little splatters all over the paint. then with a bucket of water, some 800 sandpaper and your block you rub really lightly and evenly till all the matte black paint is gone. te little splatters of matte will fill the holes where you can see peel and are the lowest point of the paint, so you wanna rub everything else flat to the same height.
when all the black is gone you go over it again with 2000 to start to shine it up, then cut it then polish.
its basically getting all the big scratches into smaller scratches, then getting all the smaller scratches into tiny scratches then getting tiny scratches into swirls then flat. make sense?
