panhard rod?
quiksilver1
vu ss
hi,do i need an adjustable panhard rod if using king superlows? ive read on hear yes but bloke at suspension shop told me i dont.dont want to buy 1 for no reason.cheers
sircruisealotVS
South Brisbane
VZ LS1 Calais
you dont NEED one, but its definately advisable....without the adjustable panhard rod the diff will not be centred and you will have troubles with tyres scrubbing on the back left (amoung other things).
you should also use short travel shocks (especially in the rear) with superlows...its illegal to have uncaptured springs, not to mention very dangerous.
quiksilver1
vu ss
cheers guys,i knew i needed shortened shocks but was unsure about rod after speaking to this guy,but ill take your word.i was a bit iffy on this bloke.he also said king springs were s#@t and he wouldnt use them.THINK ill try somewhere else!!!
quiksilver1
vu ss
is there anything i should be doing to trhe front besides changing the springs??
sircruisealotVS
South Brisbane
VZ LS1 Calais
just check all the bushes...make sure they are all sweet, if any are a bit off then they will go pretty soon after you lower your car.
quiksilver1
vu ss
thanks mate im just buying all the parts just making sure i get it all. i noticed your from Logan sircruisealot.is it qld? im also from there can you recommend a place to install parts? cheers. ive been to 1 place,what a knob.!!
TheForgotten
only human......
quarantine
www.holdenscene.com
VR EXEC
dude, just do it yourself. take your time, and ask for help when you need it. it's piss easy to DIY and a hellavu lot cheaper
sircruisealotVS
South Brisbane
VZ LS1 Calais
yeah, im in QLD...i can recommend i place not to go to...pedders at slacks creek. ages ago i went in there to get some short travel shocks put in because id changed the springs and after doing the job they handed me a "inspection report" which they had done for "free".
had over $2k worth of repairs listed on it, including a new power steering pump (which i had replaced a matter of days earlier), pretty much every bush (which is fair enough, i knew i had to do them, i just hadnt got around to it as id only just bought the car)...and front struts.
when i questioned them about the power steering pump and why it needed replacing, they said it had a huge leak (it didnt) and it was "looking old and worn out"...to which i almost fell over laughing.
i told the bloke he better watch himself or ill report him to the office of fair trading, because they pump is brand new and ontop of that the prices quotes for parts and labour for the job where rediculous....id NEVER go there man.
i ended up doing all the bushes and front struts at my mechanics (i supplied the parts, cos i can get them cheap) and it cost me under a grand...
you dont need a suspension specialist or anything to install the parts, just go to a mechanic..try logan city automotive, its on monte st..just off moss st.
cliff there is a great bloke, and he wont rip you off.
quiksilver1
vu ss
cheers mate i know where monte st is,ill call past this week on my way home,once again thanks,its hard to find somewhere not out to rip you off.i have no problems doing the rear but ive never taken out front struts,think ill leave that for someone else.
