well i've started work again on the car after a much needed 2 month break! in the meantime i bought my self a MY06 STI liberty gt as a daily driver and i'm selling the verada
Replacing the engine mounts currently with the proper ones and cutting up piping to finish my intercooler piping! as soon as its all done i'll book it back into be tuned properly. Currently cold start is painful, its over fueling and i cant run it any leaner because the the car wants to stall. It could be a result of the small gapping i run to avoid spark blowout or a combination of things such as my idle valve isnt set up correctly and fuel adjustment needs to be zero'd in. either way ill get my tuner to fix up these items
once its warm the car drives like factory (except ALOT faster)
Another thing that has been on my mind is suspension. I've been thinking this for a while but only decided recently. I'll be ditching the TEMS system and installing Adjustable height/dampening rate coil overs (probably TIEN or something) additionally i'll be fitting wider rubber to the car as the car doesn't quiet go round corners like it should compared to other supra's ive been in. Stay posted. I think I'm nearly done building this car. Just aswell i guess. after that time to buy a house
