Mandah
- Aug 7, 2018
- 25
- 2
- 3
- Age
- 36
- Location
- Sydney
- Ve omega
Hi guys question on o2 sensors and replacements when a car has had an engine swap with a different year build
The Car is 2006 omega and had a Leo engine that was replaced with a 2008 Leo engine so engines were perfect matches according to Holden, but would the precat sensors be replaced with ones for a 2008 or 2006 mechanics and parts shops I’ve asked said to go by the body so replace with sensors for 2006 I’ve had them replaced but still won’t work I’m sure they are Bosch I will double check over the weekend, I seem to have absolutely no issue with the rear sensors no codes or anything they were also replaced I’m guessing the auto electrician hoped it would be the magic fix, so I’m assuming the front and rear set would be matching each other with the codes, is there anyway to know which sensors the car is meant to have whether it be 2006 or 2008 3 wire or 4 wire the originals had to be changed due to not plugging into the new engine thank you
