TTubrag
- Oct 27, 2017
- 204
- 107
- 43
- Location
- Perth
- 2016 VFII SSV Redline
Is anybody using the Penrite ProGear 70w-75 in their VF TR6060 manual trans? I've read lots of good reports over the years about it improving the old 1 -2 shift crunch when cold (mostly in VE's), and that's what I'm chasing. Plus improved protection performance, which I know from experience ATF will not do for 70,000km, let alone the recommended 150,000km.
I'm curious to know before I go experimenting though if the product is safe to use long term and will protect all components in the TR6060 boxes fitted to VF's?
Penrite does say it's compatible with Tremec T56 boxes, but the TR6060 was the next generation of M6 box from Tremec and is quite different. Apparently bushes/ synchro's etc differ in the TR6060 which is one of the reasons why Holden's recommendation is to use only Dextron III ATF.
- Any real world experience out there in forum-land?
- What are you experiences with Penrite Pro Gear or other ATF fluid alternatives?
- Anyone tried Penrite's Dextron III compatible Full Synth ATF?
- And how long have you been using an alternative fluid in your TR6060?
http://www.penriteoil.com.au/products/categories/manual-gear-differential/pro-gear-70w-75-full-syn
http://www.penriteoil.com.au/products/categories/automatic-transmission/atf-fs-full-syn
