Wow! Comparing the OEM ATF to the Penrite Pro Gear is like comparing night to day!
I finally got around to dropping the ATF and filling with ProGear. Have only been for a 10 minute spirited test drive after filling. The difference was immediately noticeable.
With the ATF, it felt like you needed to get to know the box and shift at the right RPM, put the gear selector in just the right spot before shifting and use a little gentle persuasion to get a smooth shift. Notchiness was most noticeable when the box was cold and downshifts to 2nd were the most difficult to do smoothly. You could rarely ratchet up the pace and expect the box to shift smoothly all the time.
Now with the ProGear, you can just ratchet up the pace and expect the box to shift smoothly! Like you'd expect a manual box to behave.
On a side note:
I jacked up the passenger side only to do the drain and fill. So because of the positioning of the drain and fill plugs, I got just under 4 litres into the box before the filler started to drip. For a 3.5 litre fill, that's technically an overfill. (VFII TR6060 transmission).
Should I get the car level and drop the excess out from the filler? Or should it be ok with a 300-400ml overfill? I noticed the box let off a fair bit of pressurized air when I first opened the fill plug prior to draining (box was hot from a warm-up drive). Wondering if over-pressurization could be an issue for the box/ seals?
It doesn't 'seem' to have any ventilation.
