Plastic Coating on Doors
cacaman
Red is Faster
Vr Acclaim
I own a 94 VR commodore accliam and I notice during some songs i play on my system, most sound is produced from the front speakers which is no big deal, but the thing is it makes the most anoying vibrational noises, so i pulled off the door linning and realised its the actual clear plastic linning thats glued onto the metal door thats rattling. Should i take it off? i was told that if i do water can get in onto the wires and onto the door linning and damage everything is that true or should i just go for it?
StoneX
Hastings
VE Calais-V 6.0L
It is there to protect the door trim from water/moisture. If you take it off your door trim will get wet. If you don't like the noise, replace the plastic with a later of something else that won't rattle. Something like thin waterproof foam or actually sound deaden your doors then the layer of deadener acts as the barrier.
andrewgrazier
VT COMMODORE 50th ANNIVERSARY
i went to clark rubber and got 2 M of like
its foam thats about half a cm thick
n it works great :D
but that was in my old car
but they were built the same
it stopped my splits from making an annoyin vibrating noise sometimes
StoneX
Hastings
VE Calais-V 6.0L
If you get foam, make sure it is "closed cell" which is waterproof. You don't want a big sponge in your door.
