ali.mosawi
- Feb 24, 2015
- 22
- 0
- 0
- Age
- 30
- Location
- Perth
- VX Commodore 2001
Hello People,
I really need help with my VX 2001 commodore. I already have spent huge money but can't get it fixed.
Basically, I was Driving the other day and the car turned off whilst driving. It happened quite a few times before and then started again but that day it never started and I have all the warning Signs on the DashBoard
The warning Signs are: 1) ECU 2) Battery 3) Engine Oil and 4) Serv ERROR. These 4 signs are always there.
I called in a few Mechanics and they charged heaps but couldn't fix!!
1) First Mechanic checked and then started the car from the starter motor. Eventually, he asked me to change the Angle Crack Sensor. I bought and we replaced it but Still nothing Changed!! but the mechanic Charged me $300+
He left and never picked up the phone again
Asked other few mechanics and they suggested it could be an electrical problem not engine so
2) I called in an other electrical auto mechanic. He checked every thing and told me to change the ECU and the BCM!! So I went and bought them from Wreckers. Fixed them to the car and got the new key and NOTHING CHANGED. IT DIDN'T work. It remained as before nothing changed!! all warning lights are there but RADIO CD PLAYER LIGHTS INDICATOR works
Few other things that have happened are:
1) The problem is the car Diagnostic Scanner is not working with the car. The both Mechanic had the Scanner but it was not working on my Car!!
2) I also tried the Paperclip trick to see if I get any Sign but still It didn't showed anything and everything is as same as always.
3) I also bought the ALDL USB cable with the CD but still No Luck!!!
4) I called other Mechanics they say it might be a Coil Pack or Current sensor or Blah blah!!
5) I found this forum very helpful so thought to ask from you guys if anyone has encounter this problem b4 please help me out.. I already have spent a lot and this is an old car it doesn't worth more than $2000
Thanx in Advance!!
Thanx in Advance!!
