ok need more info
apart from not starting and the diagnostic plug not working
what other issues
does car lock/unlock with remote
does red mode light stop flashing with key in ignition
do headlights work
does engine still crank with key???? without bypassing relays etc
are original BCM and ECU back in car
leave ABS disconnected for now
if you are feeling bored you could unplug instrument cluster and see if engine starts
so if you try to start engine with key please list what happens
key in - mode light stops flashing
1st notch on key - radio and accessories work
2nd notch on key - dash red warning lights come on
turn key to start - engine cranks but does not start
1) The red mode light DOESN'T stop flashing with key in ignition
2) The red radio light STOPS flashing with key in ignition but starts flashing again when the key is out of ignition
The red mode light continuously flashing no matters if I put the key in or out. I also changed the ECU and the BCM (I bought) but the red mode light still flashing. I put back the originals ECU and BCM but still the same it's just flashing.
3) Headlights (HighBeam/Normal/Park) all works ok. Radio works Ok.
4) The engine Doesn't crank with the Key. It just makes a click sound from FUSE BOARD next to the Battery BUT it does crank when ( Bypass the starter motor/ the FUSE board Next to the Batter) Only cranking doesn't start though just cranking.
5) original ECU n BCM ra back in. when ABS is disconnected all I got is an extra ABS warning sign on the dashboard + the click from the FUSE board is longer there with the ABS disconnected.
*key in - mode light stops flashing = NO, It doesn't Stop
*1st notch on key - radio and accessories work = YES, they all work Smooth
*2nd notch on key - dash red warning lights come on = YES, It's always there No matter What I disconnected or Connect. Except when the battery is disconnected
*turn key to start - engine cranks but does not start = NO, with the KEY in it doesn't crank. It only cranks with bypass the starter motor or the fuse Board.
Updates:
The 1st Mechanics called me yesterday and ask $200 to fix it. we agreed, he brought an other mechanic him. they tried for about an hour but couldn't start the car.
Then they suggested me that the Immobilizer is not working and asked me sell the car
what do you guys say ? sell or fix it?
