Pontiac G8 GXP rear diffuser
redvess
melb eastern suburbs
VE SS
thought I'd clue up people on here on a relativley cheap and simple mod to change the look of the back end of your VE's cos I havnt seen it mentioned anywhere on here yet. The pontiac GXPs got a different lower section on the rear bars heres some pics of the difference
standard
GXP
I just got myself one today and I'm going to fit it up next weekend due to it requireing a bit of modification to make it fit cos for some reason the mounting points are slightly different. they only cost around $60 from holden spare parts and the number is 92213320
heres a few more shots of some fitted to SS's
I'll put some pics up of mine once its fitted
mi04se1
need for speed
White Lake, MI
Pontiac G8GT
That is on my future mod list. On mine, it bolts right up. But, I have a G8GT.
k3v0
VE SV6
yeah saw this on the LS1 forum. looks pretty good and was gonna get it but then decided to do it when i can be bothered. Lol
Coast_Calais
sick of the idiots here
gone
varies
nice one redvess!
yeah, do let us know how the install went (some pics would be great).
I like the look of this, but would like a heads up on the cut'n'shut to fit it :D
Good luck!
davey g-force
I'm a sceptic...
"...the winner is..."
02 RX7 S8 Spirit R 13B TT & 2013 Audi A3 1.8T DSG7
I don't know about anyone else, but I find the honeycomb on the SSV rear diffuser very hard to keep properly clean.
The G8 diffuser would eliminate that problem.
Plus it looks smoother and neater too.
redvess
VE SS
ok got it fitted up today wasnt as hard as I thought it would be I was going to get a mate to help me that fitted one on his car but he never showed up so I attempted it myself with the help of a write up on the LS1 forum and was was easy as
ok steps for fitting (I've used a few shots from the guy from LS1 instead of taking the same shots myself hope he doesnt mind if he see's this)
First you need to take out the three clips underneath seen here
they pop out if you pry them with a flat blade screw driver or something like that
then you need to take out the two side clips located here
his ones were just clips but I found mine were screw in clips so they were a bit harder to get out, had to pry them first then screw them out, must depend on the year model as to which you have
next you have to unclip the 4 in the middle which is a bit fiddly trying to get your hand up into where they are
again mine were screw clips so it was a pain trying to get them out, then with all the clips out pry the tabs clear of the bar so you can pull the diffuser off
heres the difference between the 2 (my Pics)
so this is where you have to modify the GXP part, trial fit the diffuser with the 2 outside tabs inserted cos these are the only 2 that fit at this stage then score along the other tabs with the screw driver where they need to be cut then cut them with some side cutters making sure you dont cut too much better to cut too little than too much
so it should look something like this with the modified tabs
once you get it to fit snug you need to drill holes for the clips to fit in I only drilled 3 for the ones underneath but the other guy drilled holes in a few of the tabs like the origional ones but mine didnt need them it fit snug without them so I only drilled here
but if you want to use the other clips you drill here where the blue and red arrows are
before you drill the lower 3 push the diffuser as far back as you can and hold it there while marking the holes so it'll sit tight once you put the clips back in
last step is to swap the reflectors over which is just one phillips head screw in each then its cliped in on the other side
and thats all it takes heres some pics of what it turned out like starting with a before shot (I forgot to take one today)
before
after
tomholzy
VE SS II
nice,
thanks for the write-up,
im going to try this now as you have outlined it!!
tomholzy
VE SS II
im trying to get a hold of one of these diffusers, im in brisbane and no holden parts have heard of them, also tried the number redvess gave and no respone??
kuzman89
vic
VE SV6 ute
These wouldn't fit the ute would it?? The Wagon is similiar to the ute but I have my doubts
redvess
VE SS
tomholzy
VE SS II
awesome guide,
i printed this out and did it this arvo,
thanks redvess
KARTAL
Northern Suburbs - Melbourne
08 Commodore VE SV6
a bit off topic but can i ask if your spoiler is the g8 lip one that they sell @ holmart and also if so does it cover the original spoiler holes?
diffuser looks hot btw.. :)
redvess
VE SS
awesome guide,
thanks redvess
no worrries glad I could help you out :beer chug:
thanks, yeah its the G8 lip but it only covers up 2 of the holes towards the back the other 2 I have rubber plugs in but it looks ok still
mi04se1
need for speed
White Lake, MI
Pontiac G8GT
Got my diffuser today, should be on this afternoon.
ve_alloytec
Perth, WA
VE SV6
i love the look of it on the ve, but is it hard to do and is it worth it???
