lmoengnr
Donating Member
- Jan 15, 2012
- 6,977
- 45,685
- 113
- Location
- Sunbury Vic.
- MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Tube headers usually amplify any engine noise.maybe 15-20k km's
That's exactly what I'd say to my wife if I had one. Oh and "honey I had to replace the air pump too"Hi guys, ended up being all the lifters were gone and had unfortunately damaged the cam. I had no choice but to upgrade the lifters and cam. Please note that the lifter noises ended up getting a lot worse but the regular oil changes prolonged the life of the lifters
Presumably that means you’ve lost your claim?Why should common manufacturing failures, often seen in the USA and Australia even when under warranty get passed on to the next owner where remedy from the manufacturer in Australia is very unlikely. RACQ 'Holden Roadside Assist' report - 'Engine noise after start sounds like a tappet oil is ok water OK it's been an ongoing problem vehicle is still under warranty advised member vehicle is not drivable in this condition tappet noise is louder than most. Advise member to seek legal advice if they want warranty and have been denied.'
Holden Australia vehicles now operates under a new name: beware GMANZ found the following approach was successful under Australian Consumer Law when forced into a Tribunal: first control evidence and what dealers report and then in sworn submission deceive the Tribunal - i.e. that 'The engine noise concern has been inspected by two authorised Holden Service Outlets, GMANZ field representative and QCAT appointed assessor which they have all determined that the engine is not making any unusual noises' even though the first Holden Dealer applied in writing to GMANZ for a preplacement engine, and the second independently sought GMANZ for major engine repairs and reimbursement ‘to carry out the replacement of the lifters and the camshaft $5350.35 including parts and labour’ - that dealers experienced LS3 technician described the noise as a "hell of a racket" (which submitted video confirmed) - stating "definitely needs lifters". GMANZ field represented reportedly first verbally approve the repair then conducted a 'test' seen on dash cam footage as a sham. The QCAT appointed assessor conducted the test in conditions it would not be heard but found one recommended one major fault required MyLink replacement (Holden agreed with assessor but made its $2000+ repair conditional on my withdrawal of the higher cost engine fault claim from QCAT. Not as expected of ACL nor what I expected from GM Manufacturer Warranty? Will I ever buy another GM product - definitely NOT.
Fight for what is right and expected under law? ... fighting some of Australia's biggest corporations is a costly waste of time in a Tribunal that does not need to comply with procedural and legislated obligations, and legislation stated it need not consider the evidence before it and can make a decision any way it sees fit. Under the QCAT Act Sect 216 ‘False or misleading information’ is supposed to have consequences - it did not. When QCAT also violate the QCAT Act it is deemed as above accountability due to self-monitoring and alleged independence - the Queensland Attorney General confirms reply following QCAT demonstrated violations under Queensland law by its Tribunal is not acted on since 'the Attorney General cannot direct QCAT to the exercise of its jurisdiction'.
So, it seems protections do exist for those with power and influence, as they can operate above the law with total immunity. Be aware that Queensland's QCAT interpretation of Australian Consumer Law (ACL) as it stated in Hearing/reasons can be a sham while it adjudicates 'If you can start your car, travel between point A and B without it breaking down and stop the car then there is no major fault under ACL'.
That is not protections under Australian Consumer Law particularly when the vehicle has done less than 40k, been serviced as required by its own Holden dealers and is under full factory Warrantee!!!
Sorry it was a long journey - a final word on an Australian Consumer Law saga concludes with a light shined on QCAT- the matter has been widely raised elsewhere. QCAT self-review is a farce, a system designed to deny justice in a way that makes the final Supreme Court challenge unaffordable and often exceeding the value of the vehicle in question (case law provides good reasons not to go down that self-review to a costly legal path). Despite my provision of substantial cogent evidence in submissions, including made to the ACCC (which can't look at QCAT or individual cases), it demonstrated how both case respondents can get away with refusing to provide reports or evidence to QCAT, by citing GM proprietary information protection. That included refusal to disclose what had been done to our car. This QCAT charade continued for over 12 months and resembled something more akin to a Kangaroo Court than a legitimate legal process.Presumably that means you’ve lost your claim?
That’s rather disappointing that QCAT doesn’t follow law.
I thought QCAT decisions could be appealed via a QCAT internal process and then to the state supremacy court which I’d expect must consider the evidence (or appealed to the Australian high court of given its a federal bit of legislation)?
Seems the big boys get you via the old adage In for a penny in for a pound, and then claim costs cause you had the gaul to challenge them
