You could mybe run a j3 chip piggy backed off your ecu?
J3 chip is about $150 plus tune on top and is fair limited to about 8 or 10psi yes they're pretty good but also very limited. Wolf is a much better option even this old model has been proven time again at making good power. Piggy backing the wolf is just as easy as j3 and it'll also be cheaper as i already have a very good tune for a very similar setup. with some minor dyno time i can get it suited welll to my setup.
Plus i already bought the wolf
Also more info below
seperate BCM and ECU?
cant just piss off the stock ECU and replace with a delco? the boys at delcohacking.net are achieving pretty impressive things with just a simple delco ecu.
the smart-lock runs off the BCM and there is a reed switch in the key? if seperate BCM and ECU, then surely there would be just one or a few signal wires from the BCM to tell the ECU its ok to start. is the reed switch in the ignition just a simple on/off, or does it actually send the magnetic signal frequency to the BCM? i.e. can you bridge the 2 wires at the BCM and itll start? you laugh, but there are a couple of cars that are that easy to bypass.
im kinda losing myself here: stock setup is 1 coil per 2 cylinders? hence why you need 3. what kinda of inputs/outputs makes the WOLF drive the coil packs?
blah im wasting my time: can you post a link to the circuit diagram for the wolf?
Basically bcm isnt a problem. Yes it is a seperate module, all i need is at most a matching one to ecu which is easily got from wreckers. Smartlock can be bypassed quite easy u can buy smartlock bypass setups or make your own you can also get speed limiter remover kits too not that i'll need one. Delco ecu although good isnt a viable alternative you'd be much better as v6vpute said running a j3 chip there is a guy out there making close to 400rwkw on a j3 chip. The ford ecu is in some almost as good as a delco there just not the massive support of end users out there trying to make the most of them.
The coil setup is similar to v6 it runs a wasted spark system 3 coils each firing 2 opposing cylinders 1 on power stroke opposite on exhaust. The wolf has no ability to drive coils directly thus you need a 3 channel ignition module (much like the DFI on V6's) to fire the actual coils. the wolf has 4 ignition outputs but are only 5v therefore you need a module to boost it up. also has 4 injector outputs so you can run sequential on a 4cyl engine. The V5 wolf has 8 (or more) of each so you can sequential on a v8. Not that it matters real sequential only good to a certain rpm before it becomes redundant.
Anyway from what i found on internet last night and a couple things i've been told is that removing or a fail CMP/cam sensor will only result in a rough idle, maybe a missfire and poor fuel economy, which in the end is nothing as ecu wont be doing any of these.
So it's all good news i can go option 1 remove the CMP leave everything else as is. Piggyback ECU into sensor input and injector outputs and run a small seperate loom to ignition module coil and dissy. So its really going to be really simple to hook up the wolf. My plan for this is to unpick the ED ECU wiring thats still attached to wolf (grey plug in photo) go to the wreckers and cut an ecu plug off an EF with 150mm or so of wire attached and then destroy my old ecu (swapped it out for a tickford one a while ago) and use plug end off that to make an adapter loom which will go inbetween ecu and main loom making wolf easy remove if needed.
In theory thats how itll go
Installation manual and wiring diagrams can be found here Ari
http://wolfems.com/files/Installation Manual 457 1004.pdf
