Pulsing sound when braking
klavins
Australia
VE International Wagon MY09.5
When I put the brakes on the wagon seems to pulsate slightly which I assume just means that I need to replace the brake pads. However, it also sometimes makes an audible pulsating thud noise too?
AFracturedWinky
Western Australia
'10 VE Series 2 SV6 Manual - White
Hey mate,
I recently had the same troubles, it's more than likely your discs as well as the pads. I recently had the front rotors and pads replaced (under used car warranty, lucky me) however I should've had the rears inspected also as the noise is 99% better but not entirely gone.
I would recommend starting there.
vc commodore
Like the Leyland Brothers
VC, VH and VY
Pulsating through the brake pedal generally means replace rotors....So I'd be replacing both pads and rotors
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Yep, warped rotors. Replace them as well as your pads.
rings600
deception bay
vy equip
If you don't have much money you can just get them machined. Only about $20 each if you take them off for them.
namboss
42
2008 Holden VE Commodore
Well I would have thought his warped rotors are too thin to be machined...
vc commodore
VC, VH and VY
Rotors have a minimum thickness embossed into them....so providing it's not below that thickness it is legal to do so....that being said, best replace them
