GRPAVL
- Jul 1, 2013
- 78
- 0
- 0
- Location
- Auckland, NZ
- Website
- homepages.ihug.co.nz
- 1987 VL Calais Walkinshaw
Spoke to the cert man today to get the low down on brakes and what he is happy with.
The Calais 270mm rotors will have to go. He said even with decent pads they just get too spongy when you use big rims.
He is happy for me to upgrade to the 290mm v8 rotor and a vn v8 caliper but would prefer the rotor be slotted to aid in braking (though not required). quick look into new rotors, pads and some second hand calipers it would set me back about $400 (or $500 for the slotted option).
When I asked him about the 323mm ve upgrade option he said great idea if you can afford it. so far I found a post on here for about 800 AUD but waiting to see if he ships to nz. probably a bit of overkill really but man those twin spots would look good under my rims.
Time to be nice to the wife i guess.
Also sorted out the speedo cable and accelerator cable today.
Took the speedo into Robinson Instruments Onehunga and they are going to run a new cable inside the factory pipe to give me the correct fitting for the t700 box and vl cluster. Should cost about $75-$100.
Took the rb30 accelerator cable into Autostop Takanini and for $30 im getting it shortened about 65mm. This should allow the cable to wind on the throttle plate and connect to the bracket without any other mods.
Q
Q
