Quadrajet for 253
Aussie V8
VC SL/E 308/T350. 1989 FJ75 Toyota Troopcarrier
I get in the race car...
turn on the power arm the battery
turn on both the fuel pumps
turn on the fan switches
turn on the ignition
power up the instruments (by turning the key a tad)
set power to the starter motor via a big red missile switch
and push the button :)
Only to realise you left all those switches on overnight and you have flattened the battery :doh:
Aussie V8
Sorry OP for thread hijacking but...
I like the power wire retaining clips they look very similar to power steering line retaining clips :) Looks good :)
And LPG high pressure line retaining clips.
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
nup...
one quick ½ turn of the BIG RED KEY thingy went you get out
and the whole thing is dead...electrically :)
VR38
VB SL/E
Yes, it is vacuum operated, but the spring applies pressure to the secondary air flap (not the secondary throttle plate) and allows you to tune out the dreaded "bog" common to 253s running any carb rated too large for them. The secondary throttle plate will still open when called upon, but the amount of air available to it will be restricted....not starved as such.
Have a real hard think about what you have just said... they are VACUUM operated and as such will only open as far as engine demands.
restricting the VACUUM operated secondaries can only starve the engine.
VR38
VB SL/E
why would it be? primary and secondary metering are completely seperate from each other. locking that flap means the secondary rods dont lift, thus no extra fuel, no extra air. youre basically running a 230CFM twin barrel.
granted, its not gonna deliver extreme power, but if over carburation becomes a problem, its the easiest fix.
Again, as my last reply, they are vacuum operated and will only open as far as engine demands... blah blah blah.
the_boozer
no more VK
51
Shitsville Morwell
hilux
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ari666
250,000 hits
