rattling at front driver side (urgent help)
GreennySS
VYSS
hi y'all
I have a rattling noise coming out from the front driver side if i drive through small bumps, however if i slow down and drive through a hump it does not have any rattle...only if i drive through like minor road holes...then it would rattle
Please help if anyone knows about this problem, i have change the suspension links and the wheel hubs but it still there...please do help
thx
Adds_05
Central Coast, NSW
VT SS 5.7L
i have a simillar problem but im thinking its maybe in the door or under the dash as nothing seems loose in the front end
VYMAD
SILVERFOX
46
BUNDABERG Q
VY EXECUTIVE S2
By changing suspension links, do you mean sway bar link pin bushes? These are a very coomon fault, I would be starting there, easy fix, too.
gordo881005
unholy confessions
Hunter Valley
VY V6 Storm2
DO u have a pic of what your talking about 'VYMAD', i think mine is on the way out too
VR38
VB SL/E
As above, front caster rod bush, especially if the noise worsens when braking.
VYMAD
SILVERFOX
46
BUNDABERG Q
VY EXECUTIVE S2
No, I don't have a pic. If you raise the front of the vehicle, you'll see the sway bar ends at either side. From these ends you'll see a link pin attached to the sway bar end with rubber bushes. These then go straight up and have another set of rubber bushes at the top where they join the strut. From my experience, it's usually the top rubbers that "compress" and the washer type retaining plates make a kind of "jingling" noise like loose change in your pocket as bumps are driven over. If you can reach these upper bushes without raising the car at all, check if they are loose enough to rotate freely by hand- if so then you'd be up for new bushes. Not hard or expensive to replace yourself.
GreennySS
VYSS
Yea...its the link pin bushes...but its still rattling, but I check in today again and following adds_05's advice I did took off the front driver side fender and check and there is nothing wrong so I put it back again and extra tightening the screws and drive it
Then the rattling is gone...but when it start rattling it sounded like it came from somewhere like the control arms
sorry I don't have the link pin bush picture too but I'll try to take a pic and upload it
GreennySS
VYSS
The suspension links only costs abt 40 dollars from genuine holden
wrenchnut360
penrith
vt executive
hi all...
i had the same rattle with my vt exec
got new sway bar link kits from gm $30 each
and no more rattle
