Reading DTC codes from VX SS
73LJWhiteSL
Cranbourne North
Hyper Mica VX SS Series II M6
All,
I've had the check engine light come on briefly a couple of times in the last few days. When this happened 18 months ago I went and brought a Toledo ODB2 scanner, but it could never show codes.
Now when I have connected it, when the check engine light is on it tells me there are no error codes.
Can someone advise what I can use to read the codes please? It appears the $160 I spend on the Toledo OBD2 scanner was a waste of money. I don't mind spending maybe up to $200 on something that will work but I don't want to waste anymore money trying things that do not work.
Ten years ago I took it to Holden to read the codes when the check engine light would not go off and the car was running terrible and it cost me $70 because they wanted to charge me $1000 to replace the knock sensors. I did it myself for less than $500.
Car is 2002 VX SS
Thanks
Steve
lout
60
Langwarrin Victoria
try supercheap to get it scanned
you are looking $600 to $700 for halfway decent scan tool
73LJWhiteSL
Cranbourne North
Thanks heaps Lout, I was able to get that done yesterday.
What I got is:
Engine Control Module
- P0171
- DTC - Fuel System LeanBank1
ABS/ETC
- 58
DTC - Throttle Relaxer PWM InterFace Fault (Pulse Width Modulation)
Instrument
- 19
DTC - [Current] PCM Fault Logger
- 19 DTC - [History] PCM Fault Logger
I haven't found anything on them yet from what I have Googled, has anyone experienced these ones before?
Thanks
mpower
can't help on codes but for your future endeavours i recommend Envyous Customs cables and SW.
lout
60
Langwarrin Victoria
73LJWhiteSL
Cranbourne North
lout
60
Langwarrin Victoria
always include the gas system in your original post as it has a huge bearing on the diagnostics
definitely look at better quality spark plugs
mpower
yeah, it's always the gas system, aftermarket ones are a pita and afaik GM-H only ever had aftermarket.
