commsirac
Banned
- Aug 31, 2007
- 1,183
- 20
- 0
- Website
- www.google.com
- vx
It certainly does, both the open cell voltage and most importantly the voltage under load, starting ability.No, what you brought up originally was that temp effect the batt.?
Yes, that is open cell voltage. The only interest in open cell voltage and temperature is assessing the level of charge of the battery. An open cell voltage of 12.3V tells us the battery is half spent.Now read your chart, and you can clearly see that even if the battery went from almost -20 degrees to almost 50 degrees C the battery voltage will change LESS THAN 0.15 volts.?
No. If its a battery where 50% charge is still big compared to the starting demands of the car possibly. If its a battery on the way out 50% may not cut it, or if the temperature is low the voltage when cranking will be affected greatly too.So a 12.3 battery will start a car regardless of temperature.?
Its clear to me you have no idea on the terms open circuit voltage and closed circuit voltage under load. You are right the open circuit voltage varies only slightly with temperature, however, this is not the case with the voltage underload. Im only concerned with getting the car started!
Well, actually its Kopper69's, however, it supports what Im saying, so Ill stand by it too!I have included your original statement below
Please read all the information carefully.Anything to add?
If you really want to improve your understanding in this area, I am willing to help, however, you are not going about it the right way.
the bottom line is that the device that isolates the battery from the load at 11V is going to be useless if a battery is completely discharged at ~11.8V.
Ive given you a figure of 12.3V can be dicey. I didnt pull that out of fresh air, or even need to go to the link I found for you and others.
Its from the experience of dealing with keeping five cars on the road for the last 30 years in cold and warm conditions.
