Refitting stock springs in VY
mikeymikemike
VY Ute, KX250F
Hey
I got defected for being to low and need to put the original springs back in my VY ute.
But having trouble with the rears. I cant get them in. have removed the shock but still and inch or 2 long. There seems to be no room for Spring compressors .
Any Ideas?
Mike
mikeymikemike
VY Ute, KX250F
dont worrie just needed to put a bottle jack on the hub and some wood in the guard and force it down
thekid93
brisbane
vt s pack
theres under bolt u can undo to get it to drop down a bit. not sure of name but it goes from ur control arms to ur rear sway bar.
SuperSixty6
Alto Rullo
Brisbane.
Landcruiser TD
Make sure your Hand Brake is not on, Whilst installing the rears either. Release the hand brake and the cradle drops a little.
Cheers,
Super6
soop
Banned
Smithton, Tasmania.
2003 SS Commodore Series II
That'll teach you to drive a car that looks like a dog scootin its arse.
Just get a mate to stand on the hub.
Surfwagon
Sydney/NSW
AMG Mercedes C63 Wagon
To get maximum droop you need the hand brake off and the gearbox in neutral (man or auto) and you may need to also disconnect the rear sway bar.
You still may need a big screwdriver or pry bar to slip the original springs back in.
Is this only temporary or are you going to lift the car to a legal lowered height permanently.
Because it may pay to buy the right lowered springs now, fit them and be done with it.
glenn l
ve sv6
if you also leaver out the drive shafts a bit out of the diff that will give you an extra 2".
