Replace Inlet Manifold Gasket and Valves
matt089
VR Series II S-Pac 5spd
Hey guys i need to replace my inlet manifold gasket and the valve stem seals and was wondering what people reckon on prices of getting it done including parts and labour? I got quoted at ultratune around $1100 which to me is quite steep
If anyone has any idea or could help it would be appreciated
Thanks
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
If you wanted to save about $1000 you could do it yourself. Alternatively you could live with the valve stem seals leaking a bit - this does not affect efficiency, just blows a puff of blue smoke on start-up. The inlet manifold gasket you could then replace with the aid of a Gregorys manual and the search facility on this forum. Is the gasket leaking coolant or oil?
matt089
yeh its blowing out a bit of light smoke at start up and its losing coolant and oil its kind of weird for a while was losing oil and then both and now mainly just coolant
i have a manual but heard its quite a big job and dont really want the car out of action for a while
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
Check the post I've put below - mumboman has some good advice there about costs. Re the blue smoke it's not a defect as long as it goes away after a few seconds....just a nuisance and shouldn't affect normal operations unless it gets really bad. Even then there are simple methods to replace them. The $1100 quote is very very steep...almost vertical.
http://forums.justcommodores.com.au/vr-vs-holden-commodore-1993-1997/97194-hot-hot-hot.html
Good Luck.
matt089
yeh its nothing serious but its been happening for a few months now and ive just kept letting it slide lol but thinkin i should probably do something about it soon
eaton v8
my little sleeper
gladstone qld
vz 6l auto 239cam 3.9diff
Inlet manifold is a peice of cake. You could do it for under $80 and in one day if you had absolutely no idea what you were doing.
ill second that its real easy
