Dayvo
Because i can
- Apr 28, 2005
- 2,669
- 8,494
- 113
- Age
- 67
- Location
- South East,Victoria
- VE SV6 Series 2
Do you also need to use anti seize compound on the plugs
Personally I don't use anti siese on spark plugs because it's messy **** and I hate the stuff. A few drops of good quality oil on the threads and not over tightening them and you should be fine. Iff you do use anti siese make sure none gets into the combustion chambers because it will pretty much act like sandpaper in there.Do you also need to use anti seize compound on the plugs
Ok thanks, the reason I asked is that I the Gregory's manual it says to use it but when I googled it most say not to .Personally I don't use anti siese on spark plugs because it's messy **** and I hate the stuff. A few drops of good quality oil on the threads and not over tightening them and you should be fine. Iff you do use anti siese make sure none gets into the combustion chambers because it will pretty much act like sandpaper in there.
Google lies, sometimesOk thanks, the reason I asked is that I the Gregory's manual it says to use it but when I googled it most say not to .
From what I’ve read, the recommendation is apparently ‘no’. Apparently the anti-seize compound can play havoc with the torque readings - so the plugs can be easily over tightened risking breaking the plug or stripping the thread.
The other thing I have read is that the plating on the plugs severs as an anti-seize coating. But it is only good for one (or so?) application, so if the plugs are removed and reinstalled, it might not work (and the plug might seize). Some will use anti seize compound if reusing plugs (but be very careful of the torque).
To the OP, also read up on how to remove plugs from an alloy head. Don’t force them if they suddenly bind. The correct method is to work them in and out as you undo them the break up the carbon build up. So, undo them about a quarter turn or so, then screw it back in an eighth of a turn, and keep doing that until the plug completely frees up (usually within a full turn or so). Try and make them come out ‘by hand’ without having to really forcing them at all (after the initial untightening
I personally have always used a "little" smear of anti seize on plugs
I also use brake grease on caliper pins and the back of pads
The important thing is to not over tighten them, I go finger tight, then half a turn to get a gas seal
And ju
It would be a pretty boring world if every one agreed all the time.Google lies, sometimes
And just like Google, opinions may vary
As long as it is based off sound engineering principles, the Googles is too full of opinions with not alot of actual sound engineeringIt would be a pretty boring world if every one agreed all the time.
Id be curious to know the answer as well. When i first got my VE, i did the usual fluids, plugs and coils. After a quick search, i went with some Twin Tip Iridium plugs but im now wondering if theyre underperforming and i need something else. Ive had one die on me and cause a misfire.My car is the same as yours year.
Can you let me know what you get please.
And what you take out.
They are the first ones that came with the new car.
