kopper 69
Firstly the battery is a lithium and heating any type of battery, particularly lithium is not only dangerous but will shorten the batteries life. This is why there are tabs already 'welded' on to the battery using a mini spot welder
I did say it may damage the battery or explode (hence keep the heat to a minimum and wear safety glasses).:thumbsup:
I wouldnt recommend filing the battery either. Not only is the layer of metal around the battery very thin, you also risk shorting the battery out because the positive and negative terminal are so close together. In a second you could kill the battery and be putting a worse battery into the key head than you started with.
When I said file the battery, I did say SLIGHTLY. This doesn't mean totally remove the metal from the battery.
Unless you have a mini spot welder for battery tabs or will make one up, you are better off spending an extra dollar and getting a battery with the tabs (as suggested above).
Mate, if you could link me to a website that can sell these tabbed batteries, I'd be as happy a pig in crap. Looked at quite a few. Plenty without the tab, but none with. So i improvised.
Major scam that holden introduced these remotes? What would you recommend? The car is probably 15 years old and you complain that you need to replace the key. Generally by the time the battery goes flat the key is worse for wear anyway and needs replacing. Considering all the benefits the key offers - convenience and security - its hardly a scam when you need to replace the battery after this period of time.
I don't have any proplem with the convenience and security but I still think Holden are scamming on this one. Everyone I know who has had to replace a battery in a key, does not need to get the whole key replaced. For your info, the key was just on 3 years old and was in good condition. If I have to start shelling out $140 every time I need a new battery (3 to 5 years), then that's an expense that i'm not prepared to have. What your saying is that it should be quite acceptable to have spent $700 in keys for my 15 year old commodore. If you need a new key because of wear and tear, I can accept that, but for a battery change? Never heard of it on another type of car. Glad to see Holden have managed to have 'changeable' batteries on their newer commodore keys.
If you think that is bad, you should try owning a boat. Replace nearly everything on it in a never ending cycle.
Mate, as the saying goes, "if it flies, if it floats or if it f@cks, then its cheaper to hire it by the hour." This I know by personal experience.:supersad:
Rant over! :thumbsup:
