Finished extending the power window switches and it all works well.
Extended and installed the power outlet / cig lighter and works fine now. Only issue is that the little green ring doesn't light up. Not the wiring as It wasn't working at all prior to extending it.
Mock boost gauge install
Carpeted glovebox with autronic install
Hopefully picking up the TBar and
Linkage tomorrow. Also planning on grabbing a handbrake and linkage. Should hopefully bolt straight up unless the coupling at the u shackle is different in the column shift to accommodate the "drop" style handbrake.
Found an existing hole for the handrake in the tunnel. The t bar appears to require further modification for install. The tunnel appears to be a different shape in the ute also.
Still yet to hook up the Hvac panel as the heater / aircon linkage requires a mod of some sort. Very limited room makes it a pain In the ass.
All a big learning curve
