rough idle after flogging
Ben Crouch
40
NSW
VZ Acclaim Wagon
yeah so....took my beloved vz for a drive at the worst time (after getting into hot water with the missus) and gave her a bit of a thrashing now running a bit rough at idle, kind of a spluttering going on from the muffler, every now n then will drop in revs and almost cut out, where should i start lookin to fix whatever ive done to my baby..?
ant797
bunbury
vy s
might of sucked a bit of dirt into your maf at wot i would start by cleaning that
ant797
bunbury
vy s
Mass air flow sensor maf...wide open throttle wot
Fu Manchu
WA.
I once went out with a chick who had a dirty maf.
Fu Manchu
WA.
Give it a basic service.
Clean air filter, a bit of MAF sensor cleaner in its MAF. Checkout the spark plugs. Replace them would be helpful. Do a clean of the throttle body. A bit of “top end” cleaner through the intake manifold would be of use. If you do choose to replace the spark plugs, you might well have the intake off anyway so give it a good going over with the throttle body cleaner.
Some injector cleaner would be good to drop into the fuel tank.
Disconnect the battery for a while.
Lots of ideas to use here.
Fu Manchu
WA.
More importantly, go give here some nice chocies, flowers and a hug with a Sorry.
Ben Crouch
40
NSW
VZ Acclaim Wagon
only just serviced her last month, new air filter/fuel filter/oil filter/oil/oil pressure sensor/sparks and coils. was running beautifully before the flogging, just bought some maf and air intake cleaner about to do that, will try the injector cleaner too and see how we go then. unrelated question, how often is everyone changing their coolant?
