Vuman
- Dec 31, 2014
- 7
- 0
- 1
- Age
- 46
- Location
- Townsville
- VU 2001 Commo ute
Hi I purchased a vu ute recently and ever since i have had air con trouble first it was the air flow so i removed the fan from behind the glove box and blasted the little radiator thingy with water and cleaned al the leaves and dirt out my other prob is the coldness the water drips fine under the car the air is sorta cool but on a hot day it takes at-least an hour before its even reasonably comfortable to sit in I had a bloke check it with his gauges its full of gas no leaks my only concern is the 2 pipes that run into the dryer in the front end are really rusty like chunks of rust peeling off is there any other solution that somebody has had the same trouble with that could help
