I got an 8.. But if this thudding noise your getting doesn't happen in the wet and TC is turned off I'd be assuming its something else. Does it feel bouncy (for lack of a better word) when you try to spin the rear wheels in the dry?
the thud is axle tramp......not good for drive train, things snap very easy when that happens
does daddy know your thrashing his car ?
Hey mate
Heel toe brake and accelerator, rev up, side step
Are you releasing clutch or dropping the clutch?
it's a maual ute and you can't lose traction? you've probably already f**ked your clutch causing it to slip under pressure
Dump the clutch and mash the throttle, as she starts gaining traction push down on the brakes.
Pfft limiter is there to protect the engine
Okay axle tramp as I understand it is when the vehicle squats at the rear when applying power to the drive train but if it can't sustain the force to keep the wheels on the ground it sort of bounces giving you lots of downwards pressure on the rears then none..
Applying the foot brake (lightly - you don't mash the pedal when you're at WOT) is going to cause the front to lower.. It may help.. But I reckon stiffer springs in the rear.. Maybe FE2 if they aren't already installed would be a better option..
