savage1987
Donating Member
- May 8, 2005
- 3,660
- 31
- 48
- Location
- Townsville
- Website
- www.facebook.com
- LS1 VN + WK Grange 0010 + HPW VX SS
Yep. Unwrap that harness that runs past the ignition module, and you'll find all the wires for those two plugs go back up to the big intersection near the firewall so it's dead easy to poke them through and out the side. I disassembled the long plug, but couldn't get the square one to release any pins so I chose to cut and solder those wires to eliminate risk of damaging the plug itself. I put the wiring through the factory hole on the engine side wrapped in tape and convoluted tubing, and drilled a 7/8" hole for a 22mm blind rubber grommet which you can see just under the module in the photo. From then it was just a matter of rebuilding the long plug, soldering those 4 wires and tidying it all up into new tubing.
