383 hatch
- Jun 14, 2005
- 3,922
- 67
- 48
- Age
- 41
- Location
- Cowes, Phillip Island
- VG Ute 5.0,Torana hatch 383,WB Ute 5.0,VR stato5.0
Looking good.
That hole on the drivers side rear of the block with the red plug in it is the crank angle sensor hole from memory. Have a look in there and see if you can see the reluctor ring.
The hole in the back of the block is the oil pressure switch which those brass fittings screw into to enable you to use both the LS1 and VN oil pressure switches.
