Skylarking
- Feb 3, 2018
- 10,118
- 10,569
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
Loctite 406 is the all plastics superglue, good for gluing broken trim clips etc. 401 glues metals together and metal to plastic. 401 should work mint gluing a metal spud into a plastic air intake component that is already an interference fit.
Particularly external plastics, bumpers, air dams etc can be challenging to find an appropriate adhesive for the different types of plastics used in those applications.
Sikaflex 227 glued a rear diffuser to the bumper well in the is application (below) and takes a knife to cut through the Sikaflex to separate them. I used hot glue in a few places to hold it together initially and get a healthy bead of Sikaflex behind the two components to let it dry and cure. The diffuser is bolted to the body underneath and presses against the bumper cut out.
According to the manufacturer, Loctite 401 is best used with porous substrates and works for instant bonding of most plastics according to the product description. And Loctite 406 is designed especially for the fast bonding of plastics and rubbers and when combined with their superglue primers, it can also be used on difficult to bond plastics.
But even though you’ve has success with these, and I don’t doubt you have, I’ve had some problems with bonding some plastics that state they work with “most plastics”. Thats why I prefer to identify the plastic(s) needing to be bonded and then use a specific glue that mention specific suitability to the materials in question.
Sometimes trying to clean up one failed glue repair and then using another glue just adds too much of a PITA to the repair/mod process
Having said that. I’m a fan of superglues mixed with baking sofa or sawdust or carbon powder and such … Doing this can make for an interesting repair or remanufacture of otherwise unrepairable broken parts.
