I've heard they're pretty rough. One of my friends says he pretty much won't use one in any of his Nissans unless it's second hand because it will be significantly more broken in.
Do you know if you're getting a 1 way, 1.5 way, or 2 way OP?
You're mate doesn't know how to set them is the issue.
You turn the clutch packs around , change the clutch packs completely and some people leave some out , changing the stack height definitely wouldn't reccomend.
They're adjustable in the amount of lock application on throttle and on decel. A mate originally had his set up at 25% lock on Accel I laughed and said bring me it when it singles out and you've cooked a friction. You don't have enough power to let it lock that little without burning a clutch and take it drift prac. I think I ended up resetting it to 60% acceleration lock.
The 1.5 way has a slightly different engagement shape on it so on decell that it only see's half of the lock that is produced on accell.
So a 2 way with 60% lock is 60% lock on accell and decell. A 1.5 way is 60% on accell , 30% on decell.
You can set a 2 way up to behave tamer then a 1.5 way pending the situation.
I don't like them on the street due to the high level of maintenance required. If I don't plan on doing donuts I always machine and shim the cone type. If it's going to see some circle work or some actual drift prac I'd go a tru track , lokka or a Detroit locker. Lokka isn't to be confused with a spool , mini spool or cig locker. It's a brand of ratcheting locker .
