180 psiI can't read the gauge, what did it get up too?
Let there be compression
What do they call it ,flood mode?How do you do the cranking with a button start car?
or as i found out doing the flood clear the engine fires upThat's an interesting feature on the VF AFAIK if you do a comp test with WOT on a VE you set an error code to do with the throttle position and engine not running.
