Thanks, that’s how I understood the LS3 works; factory spec hardware is just bolt on with some sanity checks.
So just to reconfirm, changing factory specs by skimming the head in essence makes the pushrod seem longer (as the cam base circle to rocker distance gets physically shorter). This seemingly longer pushrod pushes the lifter’s internal piston further down into the lifter bore thus altering (increasing) preload (preload cause the piston within the lifter has a spring pushing it up against the pushrod). I’d guess that skimming the head too much would increase the preload too much, to the point the lifter‘s internal piston will bottom out within the lifter’s bore. I’d guess in such cases they’ll act much like a solid lifter but can still pump up hydraulically which ain’t really great. So the solution is to install physically shorter pushrods to keep that base circle to rocker length the same as in a standard engine and thus the lifter’s internal piston within the desired part of the lifter's bore (preloading the spring the desired amount?)…
Likewise, the flip side where one installs a cam with a smaller base circle. In that case the pushrod seemingly becomes shorter which means the preload is reduced. Reduce the preload too much and the piston will hit the retaining circlip within the lifter which means in extreme cases the push rod won’t even be retained between the lifter and rocker. Solution is a longer pushrod.
So the lifter preload that’s being discussed is the actual preloading of the piston spring within the lifter itself and thus relates to the lister’s internal piston position within the lifter. From what I’ve read, some engine builders prefer more preload (supposedly to reduce oil volume within the lifter thus reducing any compressible air bubbles within the oil) some prefer less less.
The bit I don’t understand is how one measures what the correct pushrod length should be and thus what pushrod length one needs to buy. And I also don't understand what the limits are in preload before problems start to be seen within valve train control and longevity. Guess I don’t really need to know such, just need to know a good engine builder
But without understanding stuff you’d always have to go to a mechanic or engine builder when there are funny noises with the valve train and where is the fun in that
