Should I rebuild
Stevo-vz_berlina
Qld
Vz berlina
Mine is getting towards 220k (I think) and it purrs like a kitten, no mechanical issues what so ever, except a slight weep from the RM. I've had the common problems sorted, that being the trunnions, lifters and valve springs. Think I mentioned already to swap out the Crow springs as they are fairly well known to snap.
Yea cheers mate, sorting the new ones I don’t want another one to let go
Pollushon
Boost gives me a bar....
VY SS
Once you have the heads off and can see and spin the bottom end you'll have a good idea of its health
This was mine at 230k when I boosted it, was pretty mint, scrubbed up nicely, good compression, still some hatch on the bores
losh1971
North Tas
VE Series I SS Ute
Yeah the PAC Racing ones are better. Rev High are about the cheapest providing you buy them straight from their site and not their eBay store.
Stevo-vz_berlina
Qld
Vz berlina
Yea sweet as, when I did the lifter upgrade the first time round it looked good that’s why I wasn’t really worried. How did you clean your block?
Pollushon
VY SS
Carb cleaner, non scratch scouring pads, tonnes of rags, care and a lot of time, that pic is about halfway through, you don't want any scratches, even micro in the block
losh1971
North Tas
VE Series I SS Ute
I too had one snap, I replaced the single spring with a SH one and drove it for a few months until I could afford the trunnion upgrade and have all the springs replaced at the same time. Big job, took the mech 7hrs and that was without removing the heads.
Stevo-vz_berlina
Qld
Vz berlina
Sweet thanks
Stevo-vz_berlina
Qld
Vz berlina
Hi guys I have a 2003 vy ss With 302000 on the clock I just did an ls7 lifter upgrade comp cam 219/233 and crow cam duel valve springs and otr
xforce headers with hi flow cats and 2 and 1/2 cat back
4.11 dif gears with tru Trac
It only made 237 kw
on the dyno a lifter let go and I know have low oil pressure (reason was I had wrong valve springs in it for first run) all changed now.
I don’t know if it’s time to rebuild or do a set of lifters again and heads and bolts. I have already spent decent coin (plus we are building a house) what’s every one’s thoughts.
Cheers in advance.
Hey guys,
Compression test
Cylinder 1- 155
Cylinder 3 - 150
Cylinder 5- 155
Cylinder 7 - 160
Cylinder 2 - 155
Cylinder 4 - 160
Cylinder 6 - 160
Cylinder 8 - 155
losh1971
North Tas
VE Series I SS Ute
Comps are lower than mine. Mine were 185-190 when I last checked. Someone else might pipe in and let you know if yours are still OK. Good thing is they are fairly even.
