Speedo doesn't even know!
vylover
Ermington
VS Manual Ute
Hey guy's short and simple.. at 60-80 the speedo move's around in about 5-10km increment's just move's around and doesn't do it heaps but enough for you to be worried if your near speed camera or cop's.. I had clutch kit done so idk if that may have caused it.. anyways cheer's guys :)
just want it to be fixed and wonder if you have had the same or similar problem :) thanks again :)
Jxfwsf
Aus
commodore
VSS, Cluster, wiring fault, bad connection in a plug, bad fuse contact, fault in the wiring loom or faulty ground somewhere.
Fault codes?
With all the other issues it has then maybe something is related, time to study a circuit diagram and join the dots.
You need your own sub-forum for this car.
