WogBoyz
435rkw/590rwhp
- Feb 8, 2009
- 3,151
- 16
- 0
- Location
- Cairns, Qld
- 08 VE SSV M6 Ute
bingo.
you guys should heatwrap your intake pipes also.
i would heat wrap but it would look **** lol
bingo.
+1
wheres those pics!!!!!!!!!!!!!!!
i need to do this some time soon
Smooth (larger) piping to replace the factory item would work well in increase kw. However I would avoid making it out of steel (unless it was heavily insulated) as you find that the car will become real sluggish once heat soaks into the pipe
looks factory.
looks sick as dude good work
i really gotta do this
The same reason why holden doesnt make cars come standard with high flow filters better exhuast systems ect cus a ribbed plastic intake is cheap and is fine for a stock standard car
i have the mace plenum spacer and it doesnt slow air down, it provides better flow over the runners because the stock setup the end runner doesnt get good flow and alot of dead air sits in it
i noticed an improvment from changing the pipe so it obviously done some good over the stock one
thats my 2 cents
A Plenum spacer is a special spacer that sits between your plenum cover and intake manifold. It's main purpose is to improve air distribution between cylinders by slowing down the air speed inside the plenum chamber. As a result there is less of a pressure drop inside the plenum chamber between cylinders, and less air momentum, resulting in better air distribution and power. Available in both 12mm & 25mm thickness.
