1st Problem - I'm extending the length of the rack arms, so the rack and pinion gears wont be changed at all, the spacer goes in between the rack and the tie rod.
2nd Problem - I have access to many types of steel, having an uncle who owns a machining shop makes it quite simple. He has the cnc lathe and everything.
As to this, It will be done in a workshop by people who all their engineering certs, I'll be the director of how I want it.
As it looks like it hasn't been done before on a commodore it will be a worth the effort to find out for future commodorians.
Also, I haven't been in school for the past 6 years, I doubt they would like it if i came to the workshop to work on my car.
I never said anything about ratio's.......
1st problem: extending the the distance where the rackend screws into the rack is not going to change anything, the rack will only move left and right so far before the teeth on the rack (the middle part that moves, see the bottom picture that ari posted above) runs out and the pinion (bit the steering wheel turns) can't move it anymore, hence why it's called rack and pinion steering.
Forcing it to go past what it's designed to do will simply wreck it.
It is not going to move an extra 5mm both ways.
Btw the bit between the rack and the tierod end is called a rackend, this is what you are trying to space out......
Problem 2: Well this isn't a problem.
What is circled in red is what'll stop the wheels going any further lock to lock, now they're not large bits of cast metal, so grinding them down will be A) illegal B) dangerous if it fractures further and the bottom of the strut decides it doesn't want to be connected to the lca anymore, so essentially without heavy modification and an engineering certificate that will cost a lot of money for the average commodore driver to certify that it complies with the design rules for very little gain.... (if a car won't pass a roadworthy because the rear parcel shelf has had the holes for the speakers cut bigger in the metal to fit larger ones in then i can't see this mod being even remotely possible on a registered vehicle)
