shane_3800
- Aug 13, 2011
- 4,223
- 1,798
- 113
- Age
- 35
- Location
- places
- vr commo
Hey guy's, I'm just after some extra thoughts on this.
So I have a spare banana manifold, so I cut the plenum floor off to take some measurements.
What I've got is the plenum entry is 41mm dia which gives a 132mm square cross sectional area. Then the rectangle exit to the head is 27mm x 48mm giving 129.6mm square.
The wall thickness on the runners is 5mm.
So I've read a few old threads around on the net and I saw someone claiming 268rwkw using the OE intake. So if that is true which seems high so I've been conservative and guessed it about 375hp at the fly wheel.
With my calculations a 70mm TB should be able to support 550hp plus at the flywheel.
I'm thinking if I bored the runners out to 47mm which is 173mm square which is a 76% increase, that should see the intake able to flow 550hp.
I'm thinking that my math is flawed and the intake manifold will never be able to hit these numbers.
What do you guy's think?
Also my plan to bore it is to use a flex cable from a bike brake or something like that and drill a hole in a rod to attach the flex cable with a grub screw. Then use emery paper in a slot in the bolt.
