bpefi
Tech
- Nov 5, 2009
- 260
- 3
- 0
- Location
- Bundaberg
- Hilux Ute - Vs Ecotech Engine
The injectors are fine, they have been tested, cleaned and new o rings fitted
I understand that the injectors may be ok - what you need to do is find out which cylinder is missfireing & then you can go from there - pulling injector leads is infinately safer than pulling ignition leads off to find a missing cylinder & sometimes the injector lead can be only partially on causing a miss in itself
